Clock surround
Car  Trophy,R26,GSXR1000
Right chaps just a quick one, I have a full data logging system AFR's,EGT's,Inlet temps, Boost etc..... fitted to my clio. The display unit is a perfect size to fit in the centre clock surround with a little bit of fiddling, due to the fact that I have an aftermarket head unit and it only shows the temp and time I'm quite happy to ditch it and have the data logger in there instead, anyone have any idea on how to get it out without taking tha dash out?
Steve
You can't, is the short answer. To remove the dash display it's a dash-top off job, which isn't as scary as it sounds.
When I had my 182 I could have the dash removed and back together in about 40 mins :)
