Connect2 sterreo control interface - anything special needed?
loggyboy
I've bought a used one from ebay and wired it all in but cant get it to work? I've emailed the seller but thought id post here to see if there are any tricks to test/check or activate them.
It was listed for as a CTSRN003 with Alpine adated, (it has a 3.5mm stereo socket)
Headunit is alpine CDA-117ri.
what was the original head unit?
If it was a Tuner List, you'll be fine, but you'll need a CTALPINELEAD adapter lead....but that couldbe what you've said is coming with it, in which case you'll be fine.
If your original OEM stereo was an "update list" then you might be a bit stuck
I could well be wrong, when I got the alpine lead to do stalks and display they were REALLY insistent that I had the right one.
For stalks-only it might be different.
Just like Goodj said. I had this and wasted hours trying to figure it out. The instructions are crap too. really crap.
You must have an update list stereo which means you need the other connects 2 adapter.
I ended up going to a car stereo shop in Oxford and they bent me over for £70 for the right one - it wasnt a connects 2 adapter it was another brand - name escapes me.
let me try and find it....
edit.. . cant find the one I have ...
look on your old headunit and see if it says tuner list or update list. that is the key to this .
