Saab 93 Aero Wagon
A guy i work with had to abandon his 406 Diesel in a layby on the A3 yesterday morning citing a major oil and coolant leak.
We retrieved the car with a trailer and went about putting it on a ramp to inspect the underneath.
It turns out one of the conrods had decided to leave the engine at about 80mph and 3500rpm, and seeing as there really isn't a hole big enough to fit a conrod it decided to create its own....well 3 of them actually.
The pics tell the story!
Bottom of the sump. Hole goes all the way from one side of the sump gasket to the other.
Here you can see the rather lonely big end minus its conrod.
Pic from the bulkhead side of the crankcase. Big end is upside down showing where the conrod sheared off!
Pic from the front of the crankcase. It did so much damage that its literally split the gearbox from the engine....you can move the gearbox around.
Where it decided to thump the starter motor on the way out. It then sheared a coolant pipe before leaving the engine bay and bouncing off down the carriageway!
