Coolant leak - aircon related?
terryc101
Morning!
Bit puzzled as to where this leak can be coming from as my 172 knowledge isn't the greatest. Had the car about a year now and in that time the aircon has never worked as a pipe to the condenser had a hole in.
Changes that last weekend, got it gassed up and it was working to its full potential and it was lovely! A few days later however and I noticed a trail of coolant coming out from under the car.
It seems to be collecting on the drivers side of the subframe just under the steering rack and from a brief investigation only when the aircon is running. I've been underneath and I can't for the life of me see where the water is actually originating from.
Any ideas what it could be? What's around that area at the rear of the engine/bulkhead?
Mr Trailer Man
That's what I hoped or condensation. But the level in the header tank is dropping too.
I think you're getting coolant and air con mixed up.
The coolant in the header tank is for the engine only, not the air con system.
The air con is a pressurised gas system so they don't leak liquid as such, the condenser unit does drip condensation though.
If your coolant level is going down, then you have a probable waterpump, heater matrix leak.
  PH2 172
It is normal for the cooling system to draw some coolant from the reservoir as the engine cools.Recheck the level with the engine hot.
Dip a finger in the discharged liquid and take a taste,you`ll soon realise if it`s coolant or pure water.
terryc101
Cheers for the replies.
I knew the aircon system didn't use coolant as such but wasn't sure if there were water pipes running into that area for the matrix etc.
The coolant dropped about 2cm over a few days.
Waterpump etc was not long done by a specialist so I hope it's nothing to do with that.
  Too many
It should be fairly obvious if it's coolant or just condensation. When it next leaks, dip some tissue or kitchen roll in the liquid and sniff it, coolant will have a smell, condensation shouldn't really. You might be able to tell from the colour too, Renault Type D is a greeny/yellowy colour
