Shhh
My 04 Clio 182 with 27k on the clock has started to whine when you rev it. Its not a fan belt squeel, but a sort of whine when you rev it from idle to 2,000rpm. After 2k the engine noise takes over and you can hear it in the background.
It sort of sounds like how your car sounds when its reversing, tho its slightly lighter pitch, and not as loud. Guy in work suspected it was a cam belt as it not made any more noise when you turned the steering wheel, put the air con on etc.
Are these problems covered under warranty, anyone have a list of what is covered and what is not.? Dont think a cam belt would be covered when its at 27k.?
What you think.? Should i drive it, i planned to ring the AA Renault Assist in the morning as the local dealer is 33mile away, and doubt they can fix it before 3 weeks sat as usual. Also no car would be available....great...!!!
