Cup racer front wheel bearing size ??????
  M3, Cup racer'd 182
I might be wrong but don't they run Laguna hubs?
If not you might be able to narrow it down slightly as my cup racer suspension was 65mm bolt spacing on the bottom hangers.
  DON'T SEND ME PM'S!!
mk1 lagunas are 40x84x38 or 40x84x39.7 as far as i can find
  M3, Cup racer'd 182
If it states that dimmension and it isnt, Why don't you take the bearing out and go to your local auto factors and try and match it up with a Renault part.
At least that way you'll know what hubs your running post back at let me know ;).
Have you spoken to Rsport's?
How about the mk2 laguna's
I supposed you've probably checked Evo but is there no part number on the hub which when put into renaults part system would show up what hub it is and also what bearing is required?
I've tried every renault I can think of that might be a donor. It's either a misprint (most likely) or it's unique
Measure up, I expect it's a 40x84x39.7
EVOgone
  Pink Cup Racer
Will have a proper look when im off tomorrow, just wanted to get some spares etc.....
EVOgone
  Pink Cup Racer
Plot thickens, my 2006 part manual states 40x86x40mm but the R-Sport 2001 one states 37x72x37....!!!!
mikekean
  996 C4S, 135i, E30x2
Pretty sure it will be the 2001 bearing, all UK cup racers were PH1 models orgionally so unlikely to be 2006 part.
EVOgone
  Pink Cup Racer
Will confirm when i look tomorrow. Now its time to find out what wishbones it uses, Laguna / Megane etc...?
  M3, Cup racer'd 182
Don't they use normal 172/182 wishbones as they use a extended lower ball joint (no10) to give the camber they have.
Here's pics from a email i received from Rsport a few month back.
And by the 2nd pic the bearing size is 40/86/40 Part no 77 11 155 298
Sorry about the quality i'll forward the email to you if you want.
EVOgone
  Pink Cup Racer
That the 2006 manual i have, R-Sport send me the 2001 manual with the different smaller wheel bearing size....
Just measured my spare hubs and they are the 86mm ones..!!!! will look at whats on the car tomorrow, carnt be bothered..!!
  182cup & 172 racecar
No,because the bolt hole spacing is different,if you tried to put those on a standard wishbone,it would need drilling.
It's just not for camber,the 'ball joint' towers are used to keep the roll centre to an acceptable level.
EVOgone
  Pink Cup Racer
Just check properly and the Hub ID is 84 not 86mm so looking like Laguna ones, wont know which type until i get the old one out....
Wishbones are looking like Laguna......
  Monaco 172 + mk1 RSi
i have nothing any good to say, but im very curious why laguna parts ? wider front track ?
  M3, Cup racer'd 182
Ah didn't know that cheers tony :).
Here's the pics of all front suspension/arm components much better quality now.
This is why we haven't gone for any of this stuff,it's all just such a confusing mix of parts,and can't be arsed with all that.
mikekean
How do i know this is going to confuse the s**t out of the parts guy at Renault when i go to order my new wishbones. God help me haha
  M3, Cup racer'd 182
It was confusing me also the guy from Rsport when i was getting parts for the suspension.
Good luck and hope you dont get a headache like i did.
EVOgone
  Pink Cup Racer
Spot on with the size, thats the one after measureing it. Was a bugger to get of (well the remaining inner sleave on the hub after pressing it out - welding torch job)..!!
  Cup In bits
Dragging this thread up from the past, I'm needing some spare front bearings to be safe.
40x84x39.7 is Laguna mk1 right???? Which model of laguna, diesel, 2.0rt etc??
