Re: Grey With Trinkets, Russ' 29th RS Clio
Small update - it's now MOT'd
Had a spare couple of hours so got the old alternator off and fitted the new one, gates belt and was all good once I had managed to find some bolts to bolt it on with lol.
Had to whip the air filter back plate off, which needs a clean - something to add to the list lol
Once that was on, I fitted the new battery, and gave it a go starting (Not sure how long it hasn't been run for, but I think it has been about 6 months from memory) and it fired up, ran smoothly then dropped onto 3 cylinders. Great.
I tidied up quickly, then checked all the plug leads were on ok, and hoped it would clear. I got 2 miles up the road and it wasn't getting any better, so had another quick nosey round the engine bay - long story short one injector had come unplugged, but was still resting on the injector so looked like it was still connected.
Popped it over to work, got it up on the MOT ramp for it's test and had a very good going over it while it was being MOT'd.
The only bad point we could find was one ball joint has a tiny bit of play - nothing bad, and barely worth it, but as I have about 3 Clio's worth of spares I will chuck a better one on lol.
As it hasn't been used in a long time, I took it quite gentle, but I did open it up a little:
does pull well, but to my ears it doesn't quite sound 100%.
What I'm sure isn't helping is the state of the oil
Unfortunatley by the smell of it, fuel is getting into the oil, which I am guessing could be rings - I will give it an oil change and run it for the next week and see how it behaves but I'm 99% sure my spare engine will be going in it.
Sounds f**king awesome mind :race:
