other than to give the lower dash somewhere to mount to.... does the metal dash frame actually do much.
I know it bolts up to the steering column mount but does it give that much actual support?
I am still running a dash, be it with a very stripped down and lightened lower section
Ive basically cut the passenger side top dash mount and lower bracket off to use on their own and done away with the middle bit/upper mount altogether
But i notice the frame from the drivers side is better built and quite heavy so i presume maybe does support the column?
Anyone removed completely without adding any sort of replacement bar?
