Dead Battery
JohnnyE
Car  ITB'd Clio
My Trophy has been laid up for about 10 weeks and the other day I tried to start it and as I expected it didn't start. So called AA and they put a booster on it and started, he advised the battery would need replacing this was on Sunday. Once it started I let it run for just over an hour.
Next day I tried again but it wouldn't start.
I bought a new battery today but now the car wont open via both keyfobs :( It just makes a little bleep.
If the battery is that dead and wont open the car how do I get in??
Johnny
Mine did this so I just used the key in the lock when I had my new battery I opened the door and the alarm kept going off then when I got the old battery out it didn't stop, when the new battery was in I had to lock the car up to stop it, the AA have things to get into the car if you don't have door lock then it would be a case of doing what I did
Battery fitted i just need to give the car a decent run now and put this quaiffe diff a good test...
Hi Colin, aintree and Wigan the end of June and booked the Blyton double header in July...
you on any of them??
mine did this, would get increasingly weaker, then wouldnt start at all, went through 3 batterys and an alternator to find out i had a bad earth on the battery to the chassis. get a jump lead and put one end on the battery negative and one end on the engine mount and see if it bumps up the voltage
Im back behind a wheel just need to get back to work not good being self employed and off work for 9 weeks
