deleted my abs today..
  LY 182
and pedal feel, response through pedal.. basically everything is improved.
was a bit of a nightmare as i was figuring it out custom (cat171 will tell you lol) but got the in the end.
i only had to make up 2 new quite short brake pipes in the end..
used a distribution block (basically 2 tee peices machined from a bit of ali) from a non abs vauxhall combo van, and a pressure reduction valve from the rear of a ford ka..
works fantasicly and bias is near enough spot on if not still a tad to much for the rear still 300 kg front braking effort and 80kg rear, still a tad much on the rear was hoping for about 50 but still just about right.
pics/part numbers for the two parts on there way for those interested
  LY 182
yeah the car weighs sod all so it passes with flying colours
mainly pedal feel im impressed with its rock solid and its higher aswell
