Detailing Chat & Questions Thread
Adamm.
I use Gwash and it always gets the job done well. Been using it since had the car detailed but definitely going to try reset after this bottle I think to see if there's a noticeable difference.
imprezaworks
  Mk5 Golf GTI :)
Superb
Gally
Better longevity and gloss?
It's easier to use also. I think they updated reload again in 2019 but I think there are better out there now. Good topper for the cquartz range but I would reach for it. The streaking alone on certain colours and temps can be annoying.
C2V3 although not as "fancy" chemical wise, will last aslong and always looked brilliant.
Again these type of products imo are for certain things.
Al_G
  Honda S2000, C63
Good insight, thanks.
What would you recommend for a all in one type time saving solution? Something that provides gloss and longevity.
riz
  Jaguar XFR
I'm using Turtle Wax Seal n Shine on my wife's car and it's ridiculously easy to use aswell as dirt resistant. Plus it's cheap. Lots of YouTube reviews of it, the name did put me off but can honestly say it's one of the best products I have used for a long time.
  SI-STI 2.35 & RC-172
Its a very good product and will give added protection for quite some time too (y)
Geddes
  Fiesta Mk8 ST-3
On my new ST, the twin chrome rear exhaust tips were starting to get a little sut build up, so i was using the alloy wheel cloth and started to clean the tips with some APC and I've made loads of fine marks all over the chrome, I've got some gyeon chrom polish, would that get rid of the light marks with a towel? I shouldn't of used it as the alloy cloth was for the inside back of the rims.
Any ideas by hand to remove the light marks? thanks
JamesBryan
Metal polish should shift them.
Maybe some #00 grade wire wool in combination with the polish, that's usually my go to for exhaust tips.
THIS! 00 grade wire wool will work wonders in conjunction with a metal cleaner,but that combo would be a last resort,as i only use 00 grade wire wool on very tarnished metals...i would first try just a decent metal cleaner like autosol or the britemax twins that would work extremely well when using just cloths and a good amount of arm power...
Gally
Microfiber with the polish should work on most newer cars/exhausts as per above.
MLB
Only the liquid 845, was my first ever wax!
Easy and forgiving to apply and buff off, even if put on too thick.
Brilliant to use with a machine (or by hand of course) and the beading and durability are quite good as well.
If I had to name one disadvantage is that its quite easy to over apply as it's a liquid.
Top tip, warm up the bottle in some warm water the first couple of times and when using in winter as it can be quite thick and get a squirt bottle top for it from another bottle (poorboys bottle tops work well).
  Megane RS 265
Thanks for the info, think I'l invest in some as my first wax purchase.
CrippsCorner
  A250 EbAMG
Bought a new car just before lockdown and it's been sat on the drive ever since. I've noticed it doesn't smell great inside, not like terrible but stale... anyway the other day I lifted some trim and think I've found the issue. A load of old tobacco dotted around 😬
Obviously needs a good vacuum but is there a decent product I can use to neutralise? Then hang a good air freshener I guess!
JamesBryan
Autosmart Bio Brisk will sort that.
Adamm.
Collinite 845 was what I used years ago when I had my Clio and was pretty happy with it and it was easy to use and gave good beading. I'm not sure why you'd bother now with the likes of C2v3 about though.
leeds2592
  Bean 182 + E70 X5
Just use snowfoam in it. I've got a smaller version and the snowfoam cleans so much better putting it through that than through a lance.
imprezaworks
  Mk5 Golf GTI :)
Anyone give from say a das pro or similar to a rupes, flex?
Mooching because bored. The rupes £250-300. The flex are 350? Plus.
The spta I have is great, was just curious with a price difference/justify
Sunglasses_Ron
ClioSport Admin
I’ve got a DAS6 and a Rupes Bigfoot mini. If I could afford it I’d buy a Rupes Bigfoot in a heartbeat.
The Rupes is quieter and the vibration is much less than the DAS.
