Detailing products
  Clio 182 & Saxo VTR
Ive just taken delivery of my Megs PC and after doing as much research as my brain can take on DW (not alot) im looking to settle on the following products:
http://www.cleanyourcar.co.uk/polishing/meguiars-buffing-pads/cat_23.html
Im looking at getting 2 polishing and 2 finishing pad (these will fit my backing plate right?) and no cutting pad as according to the chaps at DW they said unless i have some serious paint correction to do the polishing pad will suffice (the 182 has very light swirling and thats it).
To start:
http://www.cleanyourcar.co.uk/polishing/polish/meguairs-80-speed-glaze/prod_91.html
Doesnt seem like its required but next:
http://www.cleanyourcar.co.uk/glazes/meguiars-7-show-car-glaze/prod_92.html
Sealant:
I was going to use Auto Glym extra gloss proection but ive been told it doesnt work well with oily polishes (apparently above) so ill leave that one to you guys to recommend please. :)
Then to finish:
http://www.cleanyourcar.co.uk/wax/collinite-no-845-insulator-wax/prod_208.html
Hopefully ill be ordering my autobrite lance by Friday and another washmit with a sonus clay bar and some towels (yes its a very expensive month!) but all this should give me excellent results and some products i can work with.
Id just like your opinions if theres anything i could choose better in terms of combination of product and pads as well as protecting and giving the paint a good shine. I based the products on the hard paint Clios have (according to DW) and they seem to work well according to the results ive seen, im just not 100% certain it will all work together well.
Cheers.
  Skoda Fabia vRS
i really would stay away from the Meguiars #80 and #83 for that matter aswell, they are a right pain to work with
id go for the Sonus #1 then #3, usind the Sonus pads aswell
you wont go wrong with the Collinite but ive only ever used 476s which is brilliant, i discovered it long before it got so popular, i pimped it about lol
  Clio 182 & Saxo VTR
Ok cheers for the feedback Brun, what is it inparticular that is wrong with the megs?
Also, any links to the sonus and 476s?
This then means i can then use my AG gloss protection unless the sonus has an oily residue?
ado
  기아 &#4
I prefer Menzerna IP and FA. Would then go straight onto LP and wax.
  106 GTi
If you want to use the EGP, use some SRP first, it works lovely by machine on a finishing or polishing pad dependant on what steps you have done before. SRP really comes alive by machine.
Would not avoid #83 and #80 as they will probably work better at this time of year over the Menzerna offerings which hate the cold.
I personally would not do any corrective work unless working in doors or if it was warm enough. If I was though would also use the Menzerna IP if needed, Menzerna Final Finish, followed by SRP and then EGP or Jeffs Acrylic Jett Trigger Sealant and then top with a good carnuba.
  106 GTi
In the other extreme I would not bother doing any corrective work if it is too hot either ! If it is that hot polishes play up it is too hot to be doing it and chilling with a beer in the garden is much more appealing.
#83 can be funny if it is too warm (not a big fan tbh Poorboys SSR 2,5 for me on colder days if the Menz ain't working), never had any issues with #80 though even on warm days, work time is still long.
  Clio 182 & Saxo VTR
I was planning on doing the work outside and that was funnily enough one of my concerns, whether it would be too cold for the product to be effective. I cant however see it being a problem finding somewhere to do the work indoors.
If the SRP is effective as you say then im more than happy to use it.
So you recommend Menz > Menz FF > SRP > EGP > Carnuba?
May i ask why i would need to use the SRP after the Menz seeing as though all the corrective work should of been done with the Menz (Or should the Menz be used with a polishing pad and the Menz FF, SRP, EGP all be applied with a finishing pad)? Also would the above pads work well with these products?
Im hoping that makes sense.
Cheers again.
  106 GTi
The SRP would be purely to leave a perfect base for the EGP to bond, they are designed to work together, and by using the SRP the EGP will yield best results. After using the Menz the SRP will be fine on a finishing pad as it won't be used for corrective purpose. I tend to use EGP by hand.
In most cases you may need to use IP with a light cut pad by PC, if so I follow that up with FF on a polishing pad, and then SRP with the finishing.
Cold weather and extremely hot weather can make some products a b**ch to would with from time to time. The only machine polishes I have not had any problems with in either extremes is the Poorboys SSR range.
  Clio 182 & Saxo VTR
Awesome Rich, thanks for the advice. One final question (promise!) which cutting pad would you recommend for the Menz?
Thanks again. :)
  106 GTi
Always try it with polishing pad first though only step up to a cutting pad if you really need too. I tend to use it lots with the 5 inch Menzerna Polishing pad, as this edges toward a light cut pad and is quite effective. Cutting pads proper I use the Sonus SFX one.
  106 GTi
I have both lol!
The PO91L is the origional formula has a shorter work time and is ideal for colder days when the newer PO85RD 3.02's long work time may have you there for ages getting it to break down properly.
The PO85RD 3.02 will produce better results without the risk of dusting, it was formulated for newer harder clearcoat finishes. Will be the swine to use at this time of year in the cold though.
  106 GTi
This time of year it will probably be the better bet, come the warmer days get the PO85RD 3.02 in.
  Clio 182 & Saxo VTR
I see your point. Ok, about to order all my bits now but the menz polishing pad is 5" and im sure the backing plate for my polisher is 6" so im going to get these:
http://www.cleanyourcar.co.uk/polishing/sonus-das-foam-pads/5-dual-action-flexplate/prod_60.html
http://www.cleanyourcar.co.uk/polishing/menzerna-polishing-pads/menzerna-polishing-pad/prod_213.html
Im 99% confident that this will fit my megs one. Im assuming i can just get the Megs finishing pads and use them on my original backing plate then, again its a case of whether they work well with the product.
http://www.cleanyourcar.co.uk/polis...iars-6-5-softbuff-finishing-pad/prod_205.html
  Clio 182 & Saxo VTR
Will the megs finishing pads be ok with this?
Also a 6.5" pad ok on a 6" backing plate?
  Clio 182 & Saxo VTR
Ok, heres what i ordered (forgot clay and will get the AG from a shop local to me).
3M 3434 Masking Tape
Meguiars Foam Applicators
Menzerna Intensive Polish PO91L
Menzerna Final Finish PO106FA
5" Dual Action FlexPlate
Menzerna Polishing Pad
Meguiars 6.5" SoftBuff Finishing Pad
Sonus SFX-1 Swirl and Scratch Remover Pad
