Difference Between PH2 172 and 182 Top Inlet???
Car  C3 Picasso Beast
Basically I've got three sets of inlets that I assumed would fit a PH2 172 or a 182 (long story!!). However I've just been informed there's a difference?? What's the difference then and how do I tell if my inlets are for a 172 or a 182???
:o
That's what I thought but looking at the inlets I've got I can see a difference with one of them and that one to my knowledge shouldn't be for a PH1!!
Below are two of the inlets with the differences I can see circled on the blue one. Looking at my own car in the dark with a torch I'm guessing the blue one is a 182 and I'm hoping the black one is a PH2 172???
Another difference I haven't circled is the hole to the right of where the coil pack sits!
They are the same, only the ph1 differs
incorrect.
The extra pipe from the 182 plenum is for the carbon canister vac pipe to attach to. There is also a difference in the way the plenum sits on top of the rocker cover where the bolts go
Because of the bit I've circled at the top as the black one is different there too??
Also am I right in guessing that the other bit I've circled is a date stamp??
