Discusting farm clio
  Clio.
Bloody hell thats a bit different!
Probably the only car you wipe your feet when you get out looking at the first pics.
Are the electrics all ok with that amount of water it had inside?
GrahamS
@AlexW Yep all sorted matey. Was a breeze with the new UCH and knowing how to do the injectors, took 5 minutes. Having a right pain in the A trying to tension the manual tensioner on the belt though.
Electrics are all working fine surprisingly bar the UCH problem but it wasn't corroded, just died.
Don't have a constant live to the radio which is a little annoying but something that's an easy fix I'm sure.
GrahamS
The farm clio is now forsale! £250 takes it.
Think it's on about 160k now, doesn't use any oil, turbo is still great. Has signs of early fuel pump failure. Sunroof leaks unfortunately. Interior still in great condition now! MOT until may, can't think of a reason why it wouldn't pass. Had new wishbone and a ball joint last time.
