DIY Matched inlets
Tunst
  Focus ST225, Focus E
Since im not really using my car atm im thinking of doing some stuff with it and matched inlets seem to be a big thing to do...
Having never done anything like this before im just assuming, all i need to do is, File/sand/grind or whatever the inlet port down to the size of the gasket?
Like so: (borrowed pic)
Or is it more complicated than that :eek:
Edit: also is it even worth the time and effort?
Tunst
Forgot to add in there, i might paint the inlet but what kinda of paint should i use? Hi-temp?
ripp
  182 FFAT
match them to the head openings. as for the paint, I used hammerite on mine, no problem so far (2 months since)
Ive used Hammerite and normal spray paint in the past (with etch primer) and both have been 100% fine, 24 months later..
Tunst
Would not diy it tbh
Why not? Im a mechanic so will probaly have most of the tools needed to do it...
Sounds simple enough, Might give it a go next weekend. I have a few tubs of hammerite so thats covered..
  Stripped yozza'd cup
Lol. Unless you understand what you're doing, don't do it. Gas flowing isn't just about the size of the hole.
ripp
  182 FFAT
would be good to study a already matched inlet and see how much material and where from has been removed. but matching to the head and being careful about doing it you shouldn't go wrong
  172
From what ive read, Some of the 'pro' ones are pretty shoddy so why not do it yourself.
Scribe round a used gasket, dremel almost upto the line, dont go too far. You want the head port to be slightly larger than the inlet ( IIRC? This could be b****cks) Think you only want to go up about 1" if that.
Tunst
This would be ideal if i knew someone with them :boring:
Im gonna give it ago, im just going to start with the inlets, if i think iv done them well il match them to the head. i might just buy another set and play around with them, just incase i need to use the car..
Il report back when iv done it :)
There is a difference between matching to the head/plenum and removing material for the full length of the manifold.
The former is fairly straight forward, with the latter you have to know what you're doing.
Greeny.
  440i + 182
Good idea if you can do it well, although id always rather get them CNC matched as it isnt that expensive and will ensure your getting the best airflow.
Daniel
  Whichever has fuel
How do you go about matching it to the head and not the gasket??
  Black Gold Trophy
The best thing to do is put the gasket on the head and check how close that is, then make adjustments if necessary, mine was perfect so used it as my template.
wilky19
  Leon FR 184
i made a template out of masking tape for the head.
just got to by a new dremel then ill do mine.
  ITB'd MK1
the head to lower manifold gasket has holes that are bigger than the ports so you have to be careful not to go out as far as that. If you put the gasket on a head you'll see what i mean. The upper to lower join will be pretty much perfect if you match to the gasket.
I saw a car on thursday that had the lower inlet bored out so much, the gasket was a lot smaller than the port and was just overhanging. No benefit to that at all
  Black Gold Trophy
suppose quality control is something to be desired with most of the components^
My gasket matched perfectly to the head, so I guess I was lucky!
