Re: dmallett's 421'd monaco
And so it begins.
I now own a ph1 on 89k
Few things about the car.
Belts done in 2011 at 62k by BTM.
Matched inlets
Decat
Piper exhaust
My original pikey induction kit
Half cage
Cobra seats
Raceland coilovers
Flocked Dash
The williams wheels on it arent mine, yes i bought a car with out wheels
And various other bits and bobs.
So the plan?
Well the plan is to build between my 2 clios one decent one to exactly how I want it. The ph1 will run a standard engine with no aircon, the matched inlets and some form of induction kit with a decatted piper system. The clio has a very strong engine in it, Rhys Beal will vouch for me on that as hes played with it on the old airfield near us.
The whole interior will be stripped down and refitting with a the ph2 interior. I will be using my cobra imola 2 as a drivers seat and the cobra monaco as a passenger seat. The car will retain its full interior except for rear seats, the cage will have harness bars added to it and i will run 4 point harness's either side, this will also be sprayed black to be as descreet as a cage can ha.
Suspension/brakes wise the following will be fitted to the ph1 from the ph2; spax coilovers, whiteline arb, 25mm front spacers, 5mm rear, brembo hc discs, mintex m1155 front pads, standard spec brembo rear discs and pads. My OZ F1's will be going onto the ph1 with 595 RS-R's, eventually these will be painted silver to make the car look pretty much normal.
If that all makes sense then that is my plan
And i know people will wonder why the epic 421'd engine wont be going in the ph1 simply because I want to run a stanard engine to keep all options open for the future for the car as pursuing the N/a route leads to me being bored and changing car every few months
The remainder of the parts will be sold and the ph2 broken (sorry Dan, you can slap me when you see me!)
Anyway thats the most ive ever written on here so some s**t pictures as per usual.
Progress has already begun, the exhaust was broken so thats now off to have a shim put over the centre section and re-welded. Exhaust bar that split is in very good condition, i expect the silly lows this car has may of caused it!
Cheers for reading
thread should be getting updated quite abit in the coming month. Oh and ill ask a mod to change the thread title as and when I think of something!
