Dodo Juice has arrived
  Shed.
Well.........
Im guna go apply the s**t soon, so whats the best way, ive just remembered ive got some meguirs foam applicators. I prefer using the Microfirbe ones to apply polish, but would it be best to use the foam ones. They might be covered in bumpercare stuff though so mf might be the only option.
Do i get the applicator, and work the wax in a circular motion and then apply ? not sure what to do really. Ill be washing and polishing and then applying egp first.
Ali
  V6, Trackhawk, GTS
Foam applicators are all i use for wax. The megs ones are fine.
I wax in lines, the dodo juice is very easy to apply and layer. Apply as thiny as possible. Bring the wax inside to warm before you use it.
  106 GTi
As above - it will stain the foam hand pad in use so dedicate one to Dodo duties ...
  Mito Sportiva 135
Its all about foam pads lol. I do straight overlaping lines one way, then over again vertically to ensure 100% even coverage.
I normally leave waxes to cure for about 10 minutes at least.
  Shed.
kk iv e given mine a wash now so its all good. Egp is drying anyways.
Right ill leave it for 10 mins after applying it, when buffing is there anything i should know. ive got the der wunder buffing towels now btw arent i clever.
OK. It took me about 3 weeks to get rid of the shitty wax the stealership used, was streaky as hell.
TeZ
  Non RS : (
just let it cure dont have to be 10 mins may take longer may take less time ,
you will see a change in the hazing,
what wax did you go for?
  106 GTi
One thing to know is you should leave it 24 hours after applying the EGP before you wax.
  106 GTi
The EGP wont set up and bond properly unless you let it cure ie if you top it with wax to early. May as well have just gone SRP to Wax and skipped the EGP.
  mini cooper (RIP 172)
has it not been raining all day at your mike? it has here:eek:
i was gona give my car the winter treament 2day;)
  Shed.
aye it was raining when i washed it, but i have a garage so i shove it in there lol.
kk ill remember that rich, thanks for the advice, much apreciated. Still, it looks bloody good with it on now.
