Does the size of the brake fluid reservoir bottle matter?
dann2707
As above really. I'm relocating my clutch and brake reservoir bottles.
Going to use custom sized ones and wondering if I can use motorbike ones, they're smaller but does it matter? It's not like they're used to dissipate heat or anything?
I can get the motorbike ones with brackets for a much much lower price than any others so would appear advice. Thanks
In general , the car reservoirs hold approx 500ml . Incase of a leak ect , gives you time to pull over .
If your running motor bike one ie smaller , that's not a major issue in theory , just an issue if you don't have a low level warning ect .
I would want to know if the level was going down &dann2707
Seems to me that the only function is to prevent air getting into the pressure line. The ones from Tilton etc are also very small, so I don't think it will be an issue. And the ones you are going to use also work very well on a motorbike.
depends on use of the car and if it's a dedicated track car pad use, as pad wears pistons sit further out so you've got to have enough in reserve to cover the excess fluid.
