Elbow size for Ph1 172
Car  CLIO 172 PH1
Want to replace the orginal plastic tube to samco elbow on my Ph1 172 ( Orginal air box to throttle) What size elbow should i order and where can i get it?
How about the idle control valve? Just leave it to atmosphere or put a little filter on it?? Thank you:boring:
70mm
can be had on ebay or from samco direct etc
idle control valve? you mean the oil breather that goes into the inlet pipe?
you can get a self sealing take off from merlin motorsport that will do the job, go to samco on their webiste and you will find it
70mm
I think that is what i'm talking about. The valve i mention was attached on the inlet manifold behide the throttle. It had a plactic tube conneting the air box pipe. THX
70mm
70mm at both sise?? thx :boring:
Your origional guess at the idle control valve was correct, a breather filter on it will be fine.
