electrical fault
I have a problem where by when I press the brake the thermometer goes out, the stereo dimms and the klight in the glovebox goes on!
I am thinking it could be a weak earth on the brakelight.....but before i dive in there, any other bright ideas on this one?
All help much appreciated
  Was a Clio 1.8 16v
Earths usually work as normal or dont at all i think. Doubt they can cause that. Maybe something to do with the lives to the display or brake lights. :confused:
Check the switch on the pedal is being operated correctly when you puch the pedal. Check the 2 spade teminals on the pedal-quite possibly a bad earth somewhere, pull both rear clusters off and investigate,
