Engine light i think...Need help!!!
Car  Renault Clio Dynamique
Quite a few times this week i have accelarated and the car jurks a little then the red engine management light i think (Shape of engine with stop in the middle) flashes along with the red stop light. Nothing seems wrong as i drive but the light wont go off until i stop turn off the engine then back on and the light is off.
Any suggestions as to what this might be
Cheers in advance :)
It's the coolant temp light. Coolant temp sensor is probably buggered, causing the jerkiness. Not much to replace but get it plugged in at a garage just to be sure. Circa £30 for a read-out....
Well, £30 for it be be plugged in and tell you the fault. If it is the coolant sensor it'll cost however much the sensor os then labour if you get a garage to do it (Easily DIY though)....
local place to me does the CLiP diagnostic for a tenner. however renault wanted £72 to do the same job so deffo worth ringing around.
