Engine Mounts - adjusting
  BMW 320d SE
Anyone remember a thread on this a while back. To do with moving the 182 engine back on its mounts. It had pics and everything.
I'm pretty certain that my engine is moving on it's mounts - I can hear a clunk sound when I go from 1st to reverse and vice versa, and it's causing my exhaust to split at the join of the mid-section and the cat.
  Lots of Alfas
You can try moving the engine forward. Loosen the bolts on the drivers side mount pull the engine forward with the mount plate and re-tighten. It should have the gap show in the pic at the front of the mount, not the back (arrowed)if that makes sense.
  C63 AMG, F430 & 172
also on that pic. undo the 4 bolts (16mm) and use a big bar to pull the engine to the front of the car as far as it will go. then nip them up tight!!
watch the aicon pipes
ChrisR
Can also stick a washer underneath the bolts as well as the mounts start to sag after a while, or something along those lines.
  BMW 320d SE
Brilliant. That was the sort of thing I was after. Cheers peeps. I shall try that next time I have a few hours to spare. :approve:
  BMW 320d SE
OK. So this is what mine is like at present. I take it that the whole mount moves forwards, not the inner part with the rubber on each side?
  Lots of Alfas
^Hmmm I cant see that moving much anymore, you already have the majority of the gap at the front. You can check the otherside under the battery, that will move a little too, if your still getting the problem it could be the lower gearbox dogbone mount.
  BMW 320d SE
Ok cool. I'll check the other two mounts next time I have a day off. What am I looking for in the other mounts? Ovalled bolt holes? Perished rubber?
