Engine Mounts/Oil Smear..
Noticed a small smear of oil from around the area of the plastic blanking cap (camshaft?) on the RHS of the engine when facing the front of the car. It looks like it might have got there from the rocker cover gasket (?)....Anyone else had this...did a search and found a Capn Slarty response which was scary...
Also with the engine cover off I have been man handling the engine to see what sort of movement there is from the engine mounts and Im getting a clicking side from the LHS engine mount. I would imagine this would be amplified when the engine is running....
Should there be much movement/noise?
Ta......
it should move about 1/2-1 inch when its nice........no noise should be associated with the movement.
And i dont understand the oily bit......pics?
Ben
Ill try and get some pics - It was a crap description.....
When you talk about movement do you mean by hand or when the engine is running and being revved...?
Ta
Arjun
when you have the handbrake up, and rev the motor whilst slipping the clutch to biting point.......just to check the mounts.
