Quote: Originally posted by marco on 23 October 2003
ian172,
I,ve read a "Technical Bulletin" that Renault send to their dealers warning them NOT to use synthetic oil with a viscousity index LOWER then 10W-xx. (so NO 5W-xxxxx but 10W-xxxx or 20W-xxxx ) otherwise ,because the F4R-engine has a very high compression ratio (1:11) the big-end or crankshaft bearings will break the thinner and weaker oil film of the 5W-xx oil.
Also if you read the user-manual of your car carefully,youll notice that any 5W-xxx oil is not recommended for the 2.0 16V engine.......
My clio 172 (also MKI) runs on Castrol RS racing 10W60,due to the very high "warm" index (60) this oil is relatively thick and thus provides a very strong oil film..... and at the same time is relatively thin when cold. I truly recommend this oil
Marco
