ET35 with 20mm spacers been done?
Darryl_1983
Car  RB 182 Cup
I'm currently running 15" F1's with 20mm spacers, Eibach Prolines and camber bolts set to max (believed to be about 1 degrees but actual is unknown).
The 16" TD Pro Race 1.2's i've bought are ET35, am i likely to have issues with rubbing? I'm going to be running 205/45 tyres.
It's only 8mm difference, and looking at the space left between the arches it looks like it might be ok. But a search seems to suggest no spacers at all is the norm with this offset, and the max i've found is 15mm.
I'm running ET35 with 10mm spacers and 10mm extra track from the Cup subframe. I'll be going another 5mm wider with the roll centre kit so that'll be ET35 +25. I've got 205/50/15.
I have ET35 + 15mm + 205/50/15 on the Trophy's track wheels at the front. Its fine at the ride height I have it. Its close though!
Actually thinking about it I've not allowed for the extra tyre width, do its going to be 13mm extra, might be better off ditching the spacers or going down to 5 or 10 mm which will get me similar to what I'm running now.
Might put the standard 182 wheels on tonight with the 20mm spacers and see how they look.
