Exhaust hanger 182 help please
Car  2015 ST2(MO)/CorsaLE
Hi all help please mine have have started to hang that bit lower - obviously these are attached to some metal brackets on the chassis (torx 40's). i tried to undo this but couldnt seem to shift it :S :(
i only have a torx bit on a little screw driver - is there a better way of doing this :)
thanks all!! :)
thanks James! but id like to take the old ones off and fit new if i can!
im sure the screws must just unscrew out! :S
The guide i put together actually makes the exhaust sit higher than a new bracket lol.. but if you are going with a shiny new one then just get a socket on it, yes its torque in the middle but should also be socket on the outer edge
James
the screws are probably a bit fucked from water and stuff and have probably seized maybe?
oh yeah lol think i can do that! cant i! dont have to use the torx bit in the middle of the bolt do i ??? never thought of that LOL!
Glad this came up, was going to try and find that guide later to raise my exhaust :)
Well done for the guide James.
had another look since this conversation will you be able to get a socket on that type of bolt or is a torx bit a better way to sort this!??? :) thanks all!!
ok thanks Mr Fubar just wasnt sure a socket would fit on what with it not being very deep! ;)
anyone know the size of the socket if its a t40 torx head! :approve:?? save me trying lots of sockets lol
thanks all!!!:o
Bump - i only had a little go of trying to undo them but they seemed very tight??! people! :(
