E46 320D Tourer!
I'll start by telling you my current set up...
50Mb Virgin Broadband (rubbish super hub! - wireless turned off) > Belkin Play Max HD 600 (wireless on for the laptops, iphone, ipad) > Powerline adaptor (in my geek room at top rear of house) > Powerline adaptor (in living room at lower front of house, for xbox, smart tv).
My house is an old victorian house with solid brick interior walls. As a result the signal has to travel through 3 brick walls and one floor to the living room where most of our time on the internet is spent. A Lot of the wiring in the house is new and I had a new fuse board installed last summer. The powerline setup works but for some reason I dont get a gigabit speed and can be a little intermittent, I have a feeling this is down to some of the wiring being a tad older or the fact that the powerline in the living room is plugged in via an extension lead.
Before I go on to ask the questions I best say that I cant move the Belkin Play Max or the Virgin BB modem.
Ok, question time! :
I've just bought an 8 port belkin gigabit switch off of ebay to plug in to the powerline in the living room. I'd also like to buy another Belkin Play Max or N1 of some sort to plug into this switch to act as a 'booster' to the signal from upstairs. The reason for the switch is I'd like to have the Xbox, Smart TV, 3D Blu-Ray, etc plugged in and have ports free for additional gear. Would this setup work??????
If so the new setup would look like this:
Virgin BB Hub > Belkin Play Max > Powerline > Powerline > Belkin Switch > Belkin N1/Play Max as Booster.
I'm not a complete novice in this department but google cant give the answers I'm looking for before spending loads! As far as I can see the powerlines just act like a Cat5e running from router to switch/router.
Google did seem to provide a some answers, but if the above setup would work I'm assuming the 'booster' router would need to have the exact same SSID and password but a different channel to the main ap/router. Is this correct???
Im thinking these setting would be about right:
Main Belkin AP:
IP 192.168.2.1
Subnet 255.255.255.0
Gateway 192.168.0.1
'Booster AP:
IP 192.168.2.2 (or another random last digit)
Gateway 192.168.2.1
Please feel free to correct any of the above as I'll end up pulling my hair out trying different combinations of IP addresses! Oh and yes I know Belkin can be pretty rubbish but I know what I doing with their junk, well, to a degree anyway!
Thanks for looking an hope someone can help!!!
Main Belkin AP:
IP 192.168.2.1
Gateway 192.168.0.1
'Booster AP:
Gateway 192.168.2.1
