FAO YOZ/FRED/LOONEY coilover help please?
Car  Ph1 172
with all your vast knowledge on coilovers ;-), i wonder if you can help me, tried fitting my fk's to my cup today, but am some what confused by the set up of the front. on the standard strut you have, from top to bottom rubber/metal cup, 17mm nut, then rubber bush. on the coilover what do i do with the rubber bush and cup.
thanks
nathan
ok when the coilovers are delivered they come with a large nut on top of them, DISCARD this, its purley a "transportation" nut
onto the top hat of the coilover you fit the top mount bearing (make sure you put it on the right way up)
then the large rubber ring
then the brass spacer
then the 17mm nut
job done
