Ferodo ds2500 fitting
Car  Clio 182
Just fitted new pads, brembo discs and braided lines this weekend all from the good folks at yozzasport.
When fitting the pads we had to skim a little (poss 2mm) from the bottom of the steel plate for the pads to sit in the caliper correctly, has anyone else had to do this?
Just asking coz its not been mentioned before tho last time i fitted pads (mintex) i had to do the same but not so severe with the angle grinder!
Also bed in miles- when can i give them some punishment?
Did you remove the shims? I never have but Fred advises it.
In terms of bedding in, follow the instructions in the box in order to activate the compound.
Nah, kept the shims in coz they help to reduce squealing (i think) which has been mentioned as a prob with these pads on alot of threads on here.
Instructions for ds2500 aint that s**t hot coz they mention x number of stops then go to the pitlane and check pad wear i.e not for road use
Ive just took it easy last night and tonight, tho felt improvement earlier but when you stop they are v. hot.
Cant wait till they are good to go tho, certainly something that 1*2's lack, is sufficient brakes!
Go through the number of stops as specified, drive for a couple of miles without using the brakes then repeat is usually the way.
Can you not roughly carry out the number of recommended stops?
