Fitting cup spoiler guide please?
Remove 6 bolts holding the original on, remove original then refit cup spoiler and put the 6 screws in.
Its basically as simple as that. Two screws on both sides of the boot and two in the middle.
if i remember correctly there are 6 torques screws 2 on the left end, 2 on the right and 2 in the middle, the hardest part will be keeping the wiring for the brake light and the washer hose in the correct position so the spoiler can sit flush, i use double sided foam tape to hold them in place when fitting, having someone to hold it for you reall makes it allot easier
