Fog Lights - Air In Takes!
  RenaultSport Clio 172 CUP
Well, i got some insulation on it ways to block the heat from the engine getting to my cone filter, but im thinking of removing the fog lights an having an air intake.. will remove both though so it looks even. Or i could have two intakes if i can get the pipeacross?
Would like to know what it will look like on my car. Im aiming for somthing like > http://www.cliosport.net/forum/showthread.php?t=97907&highlight=intakes
but mine will be colour coded i think.
Can anyway one do a photoshop for me cheers! Picture of the front of my car can be found> http://www.tomehb.co.uk/files/172cup/October%202005/target9.html
do i just need to remove the bulb an insert a feed? or...
  Clio 172mk2
remove the fog light houseing at back i think,
speak to fred or yoz and have some cup racer brake duct ones , would look nice, + its different :)
  AB182, Audi A5 3.0
i was thinking of doing this to my mk1! if its just a pipe from fog light hole to where my induction kit is will the water go up the pipe (when it rains)?
  AB182, Audi A5 3.0
you mean as a flow back so the water cant physicaly get up the pipe?
fred how much do just the pipe ends cost? i suppose you dont do them for the mk1s tho?
  Lionel Richie
for the full kit yes
ducts alone £125 + delivery
we sell these as per there intention as a BRAKE COOLING kit, the bumper needs to be moddified for them to fit
quite expensive :p cant i just take out the bulbs an just have smaller holes ? :p an use viper tubing ? :p
ant
  yep.
ph2 fogs are different than ph1.
seemed a pain in the swingers to fix the intake to me. went for the grill.
Do you not have the bend / crush the pipe to get it into the grill??
I got this pic from some where whos is it>> (but i wud colour code)
ant
  yep.
you have to bend it yeah but then you have to bend it near the headlight anyway.
its not crushed at all, it retains its 76mm diameter all the way.
ant
  yep.
see this pic.
bumper off but archliners in place. i've drawn a line of where the front bumper goes so you can see the space left between that and the radiator [the arrows] loadsa room!!
  AB182, Audi A5 3.0
i think i'll stick to the "bass ports" you can buy from audio shops for £5 and use normal piping ;) bit of spray...never tell the diff! lol.
go on then how hard is it to take the bumper off lo :) just want to know not sure which to do yet
  182 Full Fat
Its quite tricky to reach the bolts that secure the bumper tho. As don't you have to reach in through the wheel arch liner?:eek:
ant
  yep.
just pull it out of the way, its only plastic [french plastic at that].
