Fuse list - 182
Car  200 FF Storm Grey
Does anybody know where I could find a diagram/list for the fuse layout of a 182?
Headlight adjusters don't seem to be working (pointing down) so just want to rule the fuse out.
Right had a look bt doesent seem to be anything there for the auto adjusters, or there isn't a symbol that looks like it would be it.
Could it be one of the fuses under the bonnet?
Have a look at the sensor, its attached to the rear beam, i had the same problem and turned out the sensor had broken off the beam, in my case it was only a <£5 plastic ball joint. If you look under the passenger side you will see it.
