H&R Coilovers finally fitted but.....
Car  Williams Clio
Im unsure how tight to do up the top mounts, anyone know?
Drove it home from work today and well impressed with the handling and ride, so much better than the GAZ coilovers i had on my old RT. One thing i did notice though was that the tracking was quite far out and also seemed to change while dirving.
The coilovers have an adjustable camber slot on the top hub to strut bolt hole. Im guessing i havent tightened these up enough and the camber is changing along with the toe when im cornering. Do i need different bolts for these elongated holes or just make sure the standard bolts are tightened up a bit tighter?
thanks Adi
just tight.. set them where u want the camber and crank them up!
set your camber then get your tracking done, that should sort your problems out!
