Harness / subframe set-up's
Nafoff
i currently have sparco seats with custom sidemounts and subframes and OMP harnesses,
the custom sidemounts allow me to clip my inside harness on to the subframe base (on both seats). and the custom subframes currently have the slider on.
I now have some recaro's (seats, subframes and sidemounts), there is 2 problems with this...
1. i would have to source some sliders from the original seats as this is how the recaro subrames work.
2. i think i would need to sort another way of fixing the inner harnesses as the recaro sidemounts will not have the ability to clip/bolt to like the custom ones did.
all opinions are welcome, photo's would be great, mainly of the inner harness mount points
for the harness' issue, can you use eyelets bolted through the exhaust tunnel with spreader plates on the underside? this is what ive done. i found (in my seating postion) that where the original seats came out, i could use the rear fixing hole again rather than have to drill new holes
weve established it wont work talking on fb, but heres a pic for anyone who searches it
Can you not weld some lugs onto the Recaro subframe then re-spray to tart it up? I've just installed some Cobra subframes and sliders and they sit prety sweet :)
Am i right in thinking the spreader plates need welding into the exhaust tunnel? Sorry for the stupid question.
