HDMI Cables?
  182, SQ7, Trafic
Except for the state categorically that anything over 22.8m needs a cable equaliser to work correctly ;)
Exactly what I was thinking, we've even used 25m with them built in and they haven't worked, that was a ball ache!
DrR
  VW Golf GTD
If you've got a biggish tv the difference is night and day!
  182, SQ7, Trafic
No, but we've used a few different solutions in the past. Base T single Cat6 dongles carry Ethernet, HDMI, RS232 and IR on a single cat cable!
We use Wyrestorm
MatthewR
What would people recommend if the tv only has 1 HDMI port?
Currently I have my 360 on hd component and sky on HDMI.
MatthewR
Not much point if he's using component though. There's nothing wrong with it unless he wants to attach something else HD
Is hdmi significantly better than component hd? That's all I'd rather connect up.
Ill also be getting a media streamer that's hd for Christmas.
Can anyone recommend a splitter to connect 3 x hdmi's to 1 x tv hdmi slot?
JMR
  RB 182 Cup
@ SteBurns
If you were using a scart cable before the maximum resolution you would have been able to get would be 576 pixels high on your screen.
HDMI gives you the viewing pleasure of 720 pixels or 1080 pixels depending on your tv.
The clarity of picture and sound should be LOADS better.
As *badger* said earlier, I agree with him in using www.thatcable.co.uk
Bought my HDMI leads from there - £5 or £6 each.
Easily compare short term to the £30 - £40 IXOS cables I have the Bluray hooked up with.
