headlights permanently on!!??
Car  clio 182 cup
I don't know if I'm being a bit thick here but suddenly the headlights on my 182 are permanently on once the ignition is engaged even though the switch on the stalk is definitely in the off /0 position (the top setting)
I'm away at the moment and don't have access to the manual which I've left at home, is this a fault or is there some kind of auto-headlight function that I've accidentally triggered??
Yeah auto lights, I have mine off. turn the ignition on and quickly turn the lights fully on and off twice and you should here a beep once you've done it correctly to tell you its off.
don't need the ignition on, but yea, this
Thanks for the replies, all sorted now with the switch on-off twice technique, I'm guessing it was the auto-headlights although it was happening in (dull) daylight.
mine do that all the time too .............................................................................................................. ah , hang on , i have a volvo !
