steve32c
200T
Changed front Discs and pads this weekend on my 182 and while the calipers were off thought I'd touch the paintwork up. Covered the ends of the brake line to try and minimise fluid loss. Still had a nice pool of brake fluid. Any way put everything back together ready to bleed the brakes but can't get the brake peddle to go hard no matter how many times I pump the peddle, seems as if there is no pressure in the system. Checked and topped the resevoir up so had plenty of brake fluid before I started. When the nipple is losened nothing happens when connected to bleed kit but when you just open the nipple fluid comes out no problem so it's not blocked.
Any ideas or is this a job for renault
