Help required fitting gearbox mount!!
  ph1 172
I'm currently fitting the uprated upper gearbox mount to my car. After fitting the new one the threaded bar/stud in the middle of the mount is now sticking slightly proud of the alloy battery tray carrier. As shown in pictures;
View attachment 44721View attachment 44722
Can anyone confirm if I've fitted the mount incorrectly? I've tried with the alloy spacer underneath but couldn't get any threads through on the bar to get a nut on.
I'm sure I've done something wrong but after a few cans of stella whilst fitting I'm not at my sharpest:eek:
Any help appretiated.
  ph1 172
It was once I worked out which way round it was supposed to go:eek:
Basically;
N/S wheel off.
Plastic undertray off.
Support gear box with a bit of wood on a trolley jack.
Airbox off.
Disconnect battery and remove.
Remove ecu brackets and put ecu out of the way.
Remove old mount (theres a tricky nut underneath the battery tray)
Fit new mount and put other bits back together.
Note; I have no arch liners on mine and this was an advantage to removing the nut under the battery tray. So removing the N/S arch liner would make things easier.
You could remove the battery tray to access it better but wouldn't help when fitting the new one.
The O/S Engine mount was really staright forward though. 20 minute job.
Can't wait to test drive it tommorow now. I couldn't rock the engine by hand after fitting these and started it up and gave it a few little revs and there was no movement at all.
