HELP with brake(ABS) connections ph1 and ph2 rs owners
Cro
  Meg'd r27
Can people with either ph1s and ph2s take a photo of the connector blocks where the rear abs sensor connection meets the block connector that runs to the abs computer. Its located under the passenger side. If you follow the brake lines you will find the connections, if you could take a photo of it both connected and disconnected. I've been trying to sort it out for AGES with no avail, tried a 1.2 16v but the connections to the abs computer are different. The male connector below comes from the axle and the female (bit with yellow insides and 10pin) is the bit i have coming from the abs comp, they abviously arent compatable.
