horn not working , outside for 5 hours !!
well put a omp boss and suede wheel on , have added the 3.3ohm resistors and hooked everything up, horn works fine !
then 30 mins later doesent work ! then on then off thinking to myself wtf, so have re-wired the horn connections and crimped the ends, turns out after god know how long testing that if i pulled the horns live wire it showed a voltage, so stripped it down , to find that around the stud for the wheel bolt there is some plastic housing , with the silver rings connections that link the horn to the car, (hense it can connect the voltage whilst the wheel being rotated and not snagging any cables) , its where the live is soldered onto this ring where the problem is, looks like its come loose, so once pulled it shows a voltage,
question is how on earth do i get the centre bit of the squib out , and has anyone at all had this problem before !???
Mark
  172 Cup
I had similar problems when i changing my wheel, ended up rewiring the horn to a push button on my switch panel.
  Clio 172
I need to rewire my horn to a push button, did you rewire it from the actual horn itself or follow the cables to the squib? Cheers
Pauleds
  Merc Dueliner sport
Just get a Ph1 switch lights/indicators switch with the horn button on the end and wire it into that instead
