Hose leak
Car  Clio 200 LY/SV650S
I have a 1.2 8 valve campus 07
Where the intake pipe comes in, goes into the filter then a U bend into the throttle body. The plastic covering over this, which the ht leads go inbetween, there is two plugs with two hoses coming off as well as the MAP sensor.
The hose that comes from the top right plug that is sucking air, goes down to the drivers side headlight into something I could not make out due to it being dark has split by rubbing on the alternator belt :|
What is this hose for?
From a quick look around, well 40mins....
Something for a Evap valve? Controlling fuel vapour for idle ?
Any detail on this would be much appreciated
Shaun
