Installation instructions for the Clarion OHM833 Roof Mounted LCD Screen:
9.INSTALLATION INSTRUCTIONS
The OHM733/OHM833 is an overhead, flip-down 7"/8" monitor with an infrared (IR) eye.
It will accept a video signal from any video source with composite video out. The IR eye will work
with Clarion video source products with an IR eye input.(Please check first if Adapter is necessary!).
1. Look over the vehicle for a location for the monitor. Each vehicle is different and locations will
vary. Make sure the monitor will not interfere with the driver.
2. Run necessary wires to the mounting location. When necessary cut the headliner and pull
wires through.
3. Use a 30cm x 30cm x 2cm or 1.2cm think piece of plywood to mount the OHM733/OHM833.
4. Silicone the piece of plywood to the top of the roof or screw the plywood to the dome light
mounting assembly and or the roof support rail.
5. If you don’t need full Heights of the universal Trim Ring you can cut these Ring and use than
including Rubber gasket to close cutting.
6. Once the plywood has been mounted, connect the IR, power and DIN cables to the designated
sources.
7. Make sure all wires and DIN cables are way from screws when drilling.
8. Screw the monitor and universal pod assembly (factory pre-assembled) into the plywood using
4 wood screws (not supplied). Use the shortest screws possible to prevent roof penetration.
You can find a picture (drawing) on Page 5 of the manual saved as a PDF...
http://www.prodigit.net/clarionDB/manual/2003/operation/4400/OHM833-EU.pdfhttp://www.prodigit.net/clarionDB/manual/2003/operation/4400/OHM833-EU.pdf
