How often do you change oil on 172 Cup?
  Radical SR3
I had the car serviced around 4-5 months ago and have covered 5k miles. I'm off to the Ring on Friday next week and contemplating a quick oil and filter swap before I go to keep things in shape...any thoughts?
James
  Clio 220 Trophy
I would. Then again when you come back. Although tbh I used to change the oil in mine whenever I got bored, gave me somethin to do lol
  Clio 172 cup
On mine every 4 months
Filter £6 from local motor factors
Oil 10w/40w semi synth 5 litre £16 from asda
Approx 1 hour job, i can usually undo the filter by hand if im wearing my wifes marigolds for ultimate grip strength
Simples
  197 FF Glacier White
Every 3 months or so, new OE filters, flush with cheap oil, allow to drain, fill with synthetic. Doesn't have to be top notch when you're changing this often either, my oil always comes out looking pretty healthy.
Simples
10/40 in a 172? Bit thick isn't it? Thought it was 5/40 fully synth?
  Mk5 golf gti
i used to agree with this but with experiance on the f4r i would say change every 6 months but with decentish oil
using stuff like carlube etc encourages a noisy depahser in my experiance
  Lionel Richie
first number is the viscosity at 0degC, the lower the number the thinner it is, so a 0w is thinner than a 5W - so if you live in northern sweden you'd run a 0W40 (may a 0W30 if its REALLY cold)
second number is viscosity at 100degC 40 is the same as a 40 ;) a 50 is thicker, 30 is thinner - if you lived in africa you'd run a 10W60
get it?
Gaz_
  Extreme mode
As per service schedule. Be reet. Genuine filter, elf oil, done.
Gaz_
  Extreme mode
never had a rattling dephaser yet ;)
Also I don't tend to keep cars on uber mileage either
get it?
:D Yep!
jenic
I would insert a typical halfords joke but am still trying to work out why you need it thicker in warmer countries :eek:
jenic
But if the hotter it gets, the thicker it gets, then surely in our colder countries you need to be using 10w60 and over there a 5w40. Or does it go thinner after 100degC?
jenic
Other way mate. Hotter = thinner
That makes sense chemistry wise to me.
But how come at 0degC it is 5 then at 100degC it is at 40 and a lower number is thinner so the thickness increases with heat, from 0 - 100degC at least. Or am I understanding this all wrong?
  Radical SR3
bloody hell!
Done the job today, halfords 5x40 synth and filter...sorted. AP Racing brake fluid on its way and as I was bored, I've stripped the back out to save some weight, removed the fog lights to feed air to the filter and mount my bullet cam and tomorrow I might see if either my Profi 3 or Willans harnesses will go in.
Cheers for all the help!
  Golf GTD Mk7
Ah, see what you're getting at now. The higher viscosity, the thicker the oil is. The low/high numbers are independent readings because there is no heat initially, so the viscosity measurements don't correlate. Imagine it as two different tests.
The lower the number, the higher the viscosity at the given temperature set point.
