How sensitive are ABS Rings?
Car  Black PH2 172
I think I found my ABS problem - Took rear wheels off and where some p**ck didnt put my rear disc on proply ( forget the spacer behinde disc ) The outside of my ABS ring has been rubbing against somthing, As its tooth like right angle one side and slanted the other!
Regards Tom
They cna be quite sensetive there are tolerances for the sensor. so long as your sensors ok and the teeeth are close enough to the sensor (1mm +-.25 from memoery can check) and reasonably wide you'll be fine
