BMW Z4
That's because it's for a 774 lump from a mk2 rs megane, the sump is different as the bell housing pattern is different.
The sealing procedure is the same though, the top picture is a 730/732/736/738 lump as the 774 doesn't run an aux driven water pump. It's just the tightening sequence that's different.
Ok Now im confused? So to clear that up. I shoud use the torque values and sequence from the above yes? Im using a different sequence and 8 and then 15nm for tourque on all bolts.
