CBR1000RR Fireblade
Hi,
I've just swapped out my iPhone 4 battery, it was a pretty straight forward in and out job. I've turned the handset on after the swap and everything seems to be working as it should apart from the battery seems to have 30% charge already on it.
All the guides I viewed before swapping the battery showed a completely empty battery when they turned the phone on after the swap. I'm starting the think that I have been swindled and I've bought a second hand battery.
Do you think that this sounds the case?
The battery is an official battery and came in a white and transparent sealed small plastic bag.
