is something going to melt
the big three as they are known, it will prob be fine, but you will also prob not get some voltage drop, so amp amp may not run to full potential!
good stuff matey!!
rorrie
it will be fine as long as it dont drop below 11 volts
so have you upgraded your big three rorrie???
yep, wasnt too hard (apart from had to borrow some proper crimping tool), and made quite a difference to the voltage drop.
are the jl amps the ones that porduce the same poer over a range of voltages and impadances?(sp)
Quote: Originally posted by Rorrie on 02 November 2004
are the jl amps the ones that porduce the same power over a range of voltages and impadances?(sp)
yes:D
