Give it a good hard pull matey it will come of eventually. Had a similair thing on 1 of my R5's I ended up using a rubber mallet on the other side to assist removal.
^ yup, ive try pulling the wheel off, hitting tyre sidewall, but it wont budge, but i dont really have much faith in the RENAULT JACK to be pulling or hitting too hard.
personally wouldn't hammer a tyre side wall; careful kick should do it. copper grease on the back of the wheel/hub mounting face will prevent it from reoccuring
i guess you could use a block of wood to spread the load against the tyre/rim edge if you use a hammer
Or put two bolts back in loose and lower the car so theres some weight on the wheel should break the rust free around the hub spigot thats holding it onto the car. Coppaslip around the hub when you put it back on will stop it happening.
