Juddering when letting of power
Car  182, SQ7, Trafic
When turning right and letting off power I get a huge juddering feeling from the front left wheel. People have said CV joint but had it checked twice by two garages and they say everything is fine. It still does it after having camber and tracking done.
Second garage said car was too low so I raised it but it still done it, they reckoned the driveshaft was banging on the gearbox.
I'm now at a lost cause, I've seen top mounts mentioned but this has only done it since fiting my FK Konigsports. I dunno how tight my top washer is that sits on top of he strut as I cannot tighten it as the piston on the shock doesn't come through far enough so I just rattled it on with the air gun.
If I replace top mounts do the shocks need to come right off as will f**k all my camber up :(
Which ones? Dogbone is brand new powerflex but been on two months, gearbox mount under battery tray is also brand new?!
Thanks anyway, every one seems to be clueless lol, been to 3 garages now and know one knows?!
The last knocking noise I was getting - every garage thought was my wheel-arch or CAF flapping about...
A few mates said might of been the track-rod ends starting to go...
Turned out to be 2 of my wheel nuts on the front N/S wheel were cross-threaded and broke when I went to take them out.
Means the wheel wasn't 100% flush against the hub and knocked against it at speed
