Just checking engine mounts. Are these ok??
Just took the battery out to check the mount below it. Can anyone tell me if these are in the correct position?
Well I gotta put the battery back in now, as gotta drive the car later. If anyone does see these, and thinks they need adjusting, then say lol.
To me, the one under the battery looks as though it may have moved, but I'm not sure as it's the first time I have seen it.
On my one under the battery the bolt holes were totally elongated, Im not sure but the one in the left of the pic may be the same
I tried to tighten those two bolts under the battery, but I could keep screwing forever. Is this normal?
Ok one last try. I take it nobody has ever looked at the mounts? I would like to have a go at moving them into the right place later if they need it. If not I will have to take it into Renault and get them to look at it.
they look ok, check the battery tray is still bolted to the suspension turret by the fuse box, they tend to snap at the point
Yeah, it's still attached. Oh, well I was kind of hoping that they had moved, as I get an occaisional knocking, hear it sometimes when I start the engine.
Will keep looking for causes then lol.
